Canvas Maintenance
Old 03-02-2005 | 10:25 PM
fatdaddy's Avatar
Default Canvas Maintenance
Do you guys spray your cockpit canvas for waterproofing? If so, how often and what do you use? TIA.
fatdaddy is offline
Old 03-03-2005 | 07:23 AM
Tantrum's Avatar
Default Re: Canvas Maintenance
I washed and re-sprayed my cockpit cover for the AT this past summer. Took the cover to a coin laundry and used the biggest washer and dryer they had to clean it first. Didnt use any heat in the dryer.
Then I bought a 3M Teflon Waterproofing from Boaters world. Poured that into a pressure sprayer and sprayed the canvas while it was spread out on the lawn.
Worked very well, water beads and rolls off like a fresh waxed car.
Tantrum is offline
Old 03-03-2005 | 10:19 AM
Poorsche's Avatar
303 is the cleaner and sealant for Sunbrealla--
Poorsche is offline
Old 03-04-2005 | 10:24 PM
fatdaddy's Avatar
Hey Poorsche, where can I get 303? TIA
fatdaddy is offline
Old 03-04-2005 | 10:42 PM
The West Marine and BoatUS in this area carry it.
happy hours is offline
Old 03-05-2005 | 04:09 AM
Poorsche's Avatar
We use Sunbrella in a lot of our products and the best source on info is -- http://www.sunbrella.com/usa/carecle...ngmarine.shtml --
The stuff I was talking about and that Sunbrella recommends is 303 High Tech Fabric Guard™ .
There are great care/maint tips there and the 303 is available at West and now even automotive stores because it's great on convertible tops as well.
Poorsche is offline
Old 03-05-2005 | 06:27 AM
t500hps's Avatar
21 and 42 footers
I've done the same thing as Tatrum, except for the washing machine. I may try that next time. I've just scrubbed it with a brush a day or 2 before i waterproofed it with the same stuff (starbrite makes a similiar product to 3M's)
t500hps is offline
Old 03-05-2005 | 08:03 AM
The shop that made my full cover said to use Ivory Snow detergent because it's very gentle especially on the stitching. Mix a cup or two in a five gallon pail with warm water and a very, very small amount of bleach. ( kills any possible mildew, also Ivory Snow sudses alot )
Spread the cover on the driveway and soak with a garden hose. Srub with soap mixture using an RV brush on a long handle so you can do it standing up. Rinse, rinse, rinse till no more soap comes out. Let dry and spray with water proofing from a garden type sprayer. I use a Starbrite water proofing from West Marine, about $20.00 a gallon. One gallon is enough for my 21 ft. boat cover. I do this every spring as part of routine maintenance. Cover is about 6 years old and looks like new. It also doesn't hurt that my boat is stored inside year round. Hope this helps.
David Stotz is offline
Old 03-05-2005 | 08:21 AM
offshoredrillin's Avatar
Also for anyone that has plastic windows, there is a product called Plexus, use it to clean your windows and it will also keep them soft, as it stops the plasticizers from drying out of the window
offshoredrillin is offline
Old 03-05-2005 | 08:33 AM
Indy's Avatar
Member #154
One of the keys with Sunbrella is keeping it clean. When it gets dusty or dirty, it doesn't repel water as good even if it's treated, they call it "wetting out". The small dust particles give the water a foothold and it doesn't repel as well, or not at all. I got tired of my Sunbrella cover and used a product called Aqualon, I'll never go back to Sunbrella.
Indy is online now
502SCS
Scarab
13
06-23-2008 09:50 AM
millhouse961
01-15-2008 05:56 PM
2112
0
01-05-2008 12:29 PM
flatout
2
03-14-2006 05:09 PM
25 Eagle
11-20-2002 09:26 AM
