Salt water vs Fresh water
Old 03-03-2005 | 08:44 PM
Stormrider's Avatar
JC Performance Engines
Default Salt water vs Fresh water
Who has had their boat in boat salt and fresh water and noticed a difference is speeds.
And can you attest that it was not due to altitude differences?
Stormrider is offline
Old 03-03-2005 | 08:51 PM
Sean H's Avatar
A to Z
Default Re: Salt water vs Fresh water
salt is slightly faster due to buoyancy with all other conditions being identical....
Sean H is offline
Old 03-03-2005 | 09:03 PM
t500hps's Avatar
21 and 42 footers
I bought a 330 Sundancer several years ago that was a salt water boat. On an inland river (90 miles inland/ freshwater) the boat sat almost 2 inches lower in the water. Don't know speeds, but it has to make a difference.
t500hps is offline
Old 03-03-2005 | 09:07 PM
CMG's Avatar
CMG
not a big deal with under 70 boat anyways.
Chris G.
CMG is offline
Old 03-03-2005 | 09:11 PM
GLH's Avatar
GLH
2 mph on my rig
GLH is offline
Old 03-03-2005 | 09:14 PM
Donzi38ZX's Avatar
I saw no real difference in Salt vs. Fresh. Salt is more bouyant but it is also denser. One of the magazines hashed this out a couple years ago. Temperature, humidity and altitude seemed to be much bigger factors.
Donzi38ZX is offline
Old 03-03-2005 | 09:31 PM
PhantomChaos's Avatar
Offshore vs. Onshore
2-3Mph at least
PhantomChaos is offline
Old 03-03-2005 | 09:32 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Mine was a tad faster in salt, but I could definately feel the more bouancy of the SW in the handling of both of my boats.
Sydwayz is offline
Old 03-04-2005 | 06:49 AM
Indy's Avatar
Member #154
That was Poker Runs America and they did a real in-depth analysis on the subject...they concluded that there was little difference. And yes, they confirmed that temp and humidity were much bigger factors.
Indy is offline
Old 03-04-2005 | 07:42 AM
mopower's Avatar
Toxic FORMULA
I've found temp , humidity , and altitude make more difference than salt/fresh which seems to be little to nothing in mine.
mopower is offline
