Timing Advance HP500 >
Old 03-03-2005 | 11:01 PM
Default Timing Advance HP500
Whats the scoop on pushing the timing up to get more hp out of engines?
I'm running a HP500, to get the most out of the engine should you run the timing at Mercury's recommendation or should you push it hire? The specs are for 14 deg BTDC. at idle. Is there a preferred rpm that you should set the engines timing up at?
Whats does a dyno tell you when it comes to timing.
Active Mike is offline
Old 03-03-2005 | 11:05 PM
Default Re: Timing Advance HP500
The 20* of advance comes in gradually and is all in at 3000rpm.
Griff is offline
Old 03-04-2005 | 07:59 AM
Panther's Avatar
Frank's Marine Service
We talking Carbed or EFI?
I used to run 36* total advance. Ran one on the dyno and pushed it to 38 degrees, it ran good but we backed it off to 36* when it was in the boat.
Panther is offline
Old 03-04-2005 | 08:01 AM
Panther's Avatar
On the dyno less timing will make your exhaust temps go way up. Adding more timing makes the exhaust temp go down, makes more power but then you can get into detonation if you go to far.
I usually set timing at full advance 3000-3500 rpms.
Panther is offline
Old 03-04-2005 | 09:06 AM
Panther,
How much more HP with 36* vs 34* on the dyno and can you feel the difference in the boat between the two settings?
Mark
GETTINBYE is offline
Old 03-04-2005 | 09:57 AM
Panther's Avatar
It's been a few years since the dyno pull but I think it was in the 10-15 hp range. When the timing was advanced the motor was happier and burned fuel better.
As far as seat of pants difference, you won't be able to feel it. One thing you may notice is the engine idles smoother and starts better.
Panther is offline
Old 03-05-2005 | 12:21 AM
After a good run the boat seems to take awhile to idle down.
Was thinking that maybe timing to high. Haven't stuck a timing light on it yet.
As for the engine it is carbed.
Old 03-05-2005 | 07:54 AM
jdnca1's Avatar
The 500EFI's run 36 degrees, Can't imagine pushing it much more than that on pump gas. A prior 502 mag with solid roller, dart intake, 1050 Dominator liked 36 degrees also.
jdnca1 is offline
Old 03-05-2005 | 08:55 PM
LPBoater's Avatar
I have HP500 carbs set at 37 degrees total advance - it makes a difference vs. 34 degrees. I always use either 92 or put a bottle of octane booster in - made about 2 mph difference on a 38 Fountain
LPBoater is offline
Old 03-06-2005 | 01:11 AM
LPboater,
Does your engines take awhile to idle down after you pound them a little bit? Or when you shut them down the engine seems to try to continue to run?
