how much and where to get hydrolic stearing? >
Old 03-04-2005 | 09:30 PM
Default how much and where to get hydrolic stearing?
How much would it cost to install a single ram Hydrolic stearing on my boat. Pros and Cons. 2102 VIP Victory, 350 Mag Mpi, Alpha, Thru hull ex. Thanks. Justin..Where is a good place to buy this type of product?
justinVIP is offline
Old 03-05-2005 | 07:48 AM
Scarab3DMC's Avatar
Default Re: how much and where to get hydrolic stearing?
Talk to Fred @ Trick Marine.....he's in the links....enough said
Scarab3DMC is offline
Old 03-05-2005 | 01:21 PM
Hang Time 27's Avatar
Rouph numbers I've seen, for parts only, rounded to nearest 500:
Single ram, add on system = $1,500
(still uses cable inside boat)
Dual ram, add on system = $2,500
Full hydraulic, safest way to go fast = $3,000 to $4,000.
(no more cable)
Not worth the money unless your running 75-80 and up, alot, especially in rouph water. Just my .02
Hang Time 27 is offline
Old 03-05-2005 | 01:30 PM
A few pros cons
Cons (besides cost):
On add on system = Your still using the steering cable between the wheel and the drive, which can break. Or it can just wear and create "play" in the system.
on full hydraulic system = The steering never returns to the same "center" position, so wheel will always be crooked if you don't get a symetrical steering wheel.
Pro's:
At least if cable breaks on add on system, the steering will be locked, and cannot be forced into a turn by the torque of the prop etc.............
Guess I'm up to .04 cents now.............
Old 03-05-2005 | 02:52 PM
nough said............mine works just fine!!! Thanks guys.
Old 03-05-2005 | 04:51 PM
XS performance sells a dual ram full system for about $2650.00 I just ordered one should have it in about a week.
Contact Brian Alfrey 513-407-0215
Doug
Boatally Insane is offline
Old 03-05-2005 | 05:27 PM
Registered User
Really, has any one had a cable break? I am the master abuser of toys and I have never broke a cable. The only reason a cable would break is because of improper maintenance, like no grease, and corrosion. I agree, a full system has no play, but the cable system works just as well, I can get use to the little play that a cable has over $2000 more for a full system. Excessive play in a cable steering is a sigh of a worn cable and sleeve anyway and should be replaced. If any one has had a cable break I guarantee that it's because of corrosion. Just thought I would add my two cents.
scarabman34 is offline
Old 03-05-2005 | 07:08 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
You give in too easy. Spend that $$$
US1 Fountain is offline
Old 03-05-2005 | 07:17 PM
I've never known it to happen either, but it's the warning I've I always heard. If anything, they freeze up from rust and lack of use on old boats before they break.............
Old 03-05-2005 | 07:35 PM
Ginger or Mary Ann?
Originally Posted by Hang Time 27
I've never known it to happen either, but it's the warning I've I always heard. ......
My neither. Here on OSO is the only time I hear of cable failure. And not an actual failure, just 'fore warnings'
Next they'll be saying you have to use a GPS because your regular speedo isn't accurate. Just my prediction.
