MSD Distributors >
MSD Distributors
MSD Distributors
Old 03-06-2005 | 05:12 PM
hpy540's Avatar
Thumbs down MSD Distributors
I got a use one with my box of parts and the pick up is so corroded that it cannot be used! It looks fuzzy and orange. where is the best places to get a pickup? I have never run a MSD before and the module looks small, compared to a GM hei. I have been reading on the dui dist and those seem decent but i am at the point, just like many here that this is really starting to hemorrhage money..... i have used hopped up GM stuff in the past and i like the dependability of it all. ANy Who... dose MSD offer a rebuild progra m?
hpy540 is offline
Old 03-06-2005 | 05:23 PM
mikes280's Avatar
Default Re: MSD Distributors
you can send msd back andthey will redo it for a cheep price i have done this and they gave me a new one i thank for the dist it was eather 50 or 75 bucks
mikes280 is offline
Old 03-06-2005 | 05:33 PM
Dave_N's Avatar
I recently asked tech support at MSD if there was a way to control or minimize corrosion under the distributor cap on a marine application. The said that the corrosion was due to the highly ionized air in the cap attracting moisture. Their advise was to remove the cap and dry it out between each use.
Dave
Dave_N is offline
Old 03-06-2005 | 07:09 PM
Michigan Mad Man
CRC makes a corrosion spray called SP400 we spray all the caps and everything in the distributor to keep it from corroding.
TylerCrockett is offline
Old 03-06-2005 | 07:37 PM
mikes280's Avatar
i have done this and it works well but i had forgot about thinks
mikes280 is offline
Old 03-07-2005 | 07:30 PM
Thumbs up Re: MSD Distributors
Tyler recommended this for one of the engines he built for me and it completely eliminated any corrosion. I also sprayed it inside the new distributor cap I installed each year as part of my annual tuneup.
Escape Velocity is offline
Old 03-07-2005 | 08:43 PM
RLW
I have used the MSD Distributor rebuild service.
Two years ago it was $75.00 plus shipping.
Looked like a brand new distributor when I received it.
I have to admit, there is a slight amount of corrosion again.
RLW is offline
Old 03-07-2005 | 08:53 PM
Toss the MSD crap. The stock Merc. distributor is an excellent piece when used in cojunction with a Crane HI-6M. Built in selectable curves, rev limiter, and even variable retard as well as diagnostics. Color coded harness matches merc. harness. You will have to re-index the merc. rotor which is a little tricky.
HP350SC is offline
Old 03-07-2005 | 09:45 PM
Go with the DUI system, you won't be sorry!!
TomR is offline
Old 03-07-2005 | 09:54 PM
I second the DUI recommendation. Simple, reliable, and rock solid timing.
JohnJan is offline
kidapache
Swap Shop
3
10-18-2008 07:09 PM
OldSchool
03-03-2006 08:50 PM
CAFE
02-24-2006 11:24 AM
Ran-Dom 32
27
03-08-2005 07:53 PM
