How much does a Chris Cat weigh? >
Old 03-07-2005 | 09:50 PM
Default How much does a Chris Cat weigh?
Anybody know? Bare hull? With engines?
JohnJan is offline
Old 03-08-2005 | 02:25 PM
Default Re: How much does a Chris Cat weigh?
My Chris Cat weighed about 8,500#: after removing most of the original OEM "furniture" inside the cabin. Twin blown 572's and #3 Speedmasters. No fuel.
Due
Dueclaws is offline
Old 03-08-2005 | 03:09 PM
I remember something about 8600lbs with original equipment 454, Velvet Drive, SSM IIs. I think that was correct a decade or 2 ago. But I never weighed mine.
Gary
Gary Anderson is offline
Old 03-08-2005 | 09:20 PM
American Offshore's 3100 Cat is basically a Chris Cat. With newer construction it weighs in at 6500 lbs. Bare hull and deck will be 2500 - 3000 lbs.
tomcat is offline
Old 03-09-2005 | 08:05 AM
RE: AO weight
I agree that the AO hull weight is most likely less, but the largest weight difference is in the drive train. Most AO's use Bravos, whereas most Chris Cats use Speedmasters, Borg Warner transmissions, drive shafts, bell housing coolers, etc.
Due
Dueclaws is offline
Old 03-10-2005 | 08:19 PM
Never scaled mine either it is heavy in the 8k range on the same lift as my 80 302 formula sat on and floats close to the same level as it did. My hull is tuff 1985 almost no stress cracks on it. Haven't looked at a AO to see if stringers bulkheads ect look the same. I have probably removed 3 to 4 hundred pounds from mine iron to alu heads removed arch fresh water system battery charger.
fstboater is offline
Old 03-11-2005 | 07:59 AM
fstboater
Your on LOTO at 21mm? Where are you at. And which chris cat do you have? I keep my cruiser at Yacht Club.
Gary
Old 04-07-2005 | 09:21 PM
Original paint Red Black Grey White cove past shooters stay to the left on hoist
Old 04-08-2005 | 09:17 AM
I'll look for you. I'm at Yacht Club.
Gary
wannabe
Prop Talk
16
04-15-2009 05:57 PM
jmackin
Chris Craft
11
07-27-2008 09:21 AM
marinesracing
Chris Craft
4
03-26-2008 09:35 PM
FOREVER YOUNG
Chris Craft
18
01-23-2008 11:30 AM
