How Much Intercooled Boost Can Be Run On 9.5 Comp Ratio >
Old 03-14-2005 | 02:51 PM
FASTERDAMITT's Avatar
Default How Much Intercooled Boost Can Be Run On 9.5 Comp Ratio
If I want to put a Whipple or Procharger on a 9.5cr 572 carbed engine, how much boost can I run on pump gas? I'm thinkin 3-4#'s.
FASTERDAMITT is offline
Old 03-14-2005 | 04:58 PM
Smitty's Avatar
Default Re: How Much Intercooled Boost Can Be Run On 9.5 Comp Ratio
4 lbs should be no problem. Whipples kits run 5-6 intercooled and that is on 8.75 compression. If it is carbed just richen it up a bit
Smitty is offline
Old 03-14-2005 | 06:47 PM
What about AV gas or AV and 91 mix?
Old 03-14-2005 | 07:31 PM
faster,
what kind of boat you looking at ?
Don
chromecat is offline
Old 03-14-2005 | 09:30 PM
BajaIceBreaker's Avatar
This is good info. I am building my motors now, and I am building them with the option to bold on some huffers, maybe next year.
My CR is 9.6:1 454 with Canfield aluminum heads and full roller valve train and head studs already installed.
My engine shop suggested that I have the heads o-ring'd for the head gaskets if I want to run the huffers, but the head manufacturer suggests against o-ringing the heads.
Do you think I can run 3 - 4 lbs. boost safely on 93 octane?
What about head gaskets?
BajaIceBreaker is offline
Old 03-14-2005 | 09:39 PM
Registered User
cometic multilayer head gaskets are unbelievable.
Mike
ObnoxiousThundr is offline
Old 03-14-2005 | 10:22 PM
What's up Chromecat Don,
I ordered a Superboat Y2k 30'er. It was difficult for mr to give up the American Offshore but I wanted a cabin for overnighters and still have a fast boat.
Tom
Old 03-14-2005 | 11:36 PM
good luck...
Don
Old 03-15-2005 | 08:57 AM
DO NOT USE AV GAS!!!!
Aviation fuel is engineered to run at a lower RPM than standard, or racing gasoline. Most aircraft run at about 3400 RPM Max. It is also designed to run in the thinner atmosphere of altitude. Mixing it with unleaded can actually hurt your performance. I’ve seen many people have problems, and hurt there engines trying to run AV Gas. I have personally done it without any problem, but you have to richen up your mixture to be safe, and then add some lubricants. You’re better off building the engine to run on 89 Octane, and use 93, or add in a little true race fuel.
As far as how much boost you can run with that much compression there are too many variables to answer it with a definitively. Chamber design, Cam selection, porting, headers, head material, ignition timing, and etc. will all play factors. I’ve seen people run as much as 8 lbs of boost on top of 9.5:1 compression. The rest of the engine was built around these factors. Normal cruising however was limited to 4 lbs of boost.
RumRunner is offline
Old 03-15-2005 | 09:21 AM
I don't want to pirate this thread, but I think that's what we are looking for. If we have 9.6 (or in his case, 9.25) CR, what does it take to run huffers on pump gas?
I have Canfield 310 heads (as cast) 119CC chambers and Revolution Marine exhaust manifolds, along with everything else noted above.
Can I run huffers? And what amount of boost is safe? Would and EGT Sensor be mandatory in this situation? Do I have to run chillers? Is it a must that I install a bigger gas tank (that's obvious )
