Plexiglass repair >
Plexiglass repair
Plexiglass repair
Old 03-15-2005 | 02:28 PM
Stormrider's Avatar
JC Performance Engines
Default Plexiglass repair
A mount for my winshield has cracked.
The crack should not have any structural affects.
Would just like to patch so it's not an eye sore(to me, i'm sure no one else will notice it).
Was thinking of just using some white silicone.
Any other ideas?
Stormrider is offline
Old 03-15-2005 | 04:16 PM
resurrected's Avatar
Default Re: Plexiglass repair
Is the mount you are referring to plexiglass? Depending on the type of fracture it is, a product called methyl acetate(spelling could be wrong) can repair plexiglass. You should be able to get it at your local glass shop. Try it on something else before you put it on your boat to see how it will flow!
resurrected is offline
Old 03-15-2005 | 04:23 PM
AcryliCo's Avatar
If it's a crack on acrylic you need to drill a small hole (1/16") to stop it travelling. There are a range of Weldon products you might consider although it's damn near impossible to get it to flow inside the crack. Mounting holes should be polished because any chips in the drilling may start a crack.They should also have a bushing or at least some vynil tubing so the bolts don't start something. Problem is that acrylics tend to expand and contract at a different rate than other polymers so if the mounting isn't bushed it will stress.
AcryliCo is offline
Old 03-15-2005 | 04:25 PM
AcryliCo knows more about this stuff than I do!
Old 03-16-2005 | 06:59 AM
Sorry I gave you the wrong name, the stuff is dichloramethane. Again the spelling could be wrong. I got this stuff to fab. filter boxes for an aquarium, from a friend who owns a glass shop. It is just a corrosive for acrylic.
Old 03-16-2005 | 10:04 AM
Stormrider's Avatar
Here are pics, there are actually 2 cracks. They go right through the structure. I can't see how it would crack anymore.
Let me know what you think now.
Attached Thumbnails Plexiglass repair-dsc00359.jpg   Plexiglass repair-dsc00360.jpg
Old 03-16-2005 | 12:10 PM
AcryliCo's Avatar
Ah! I've seen the problem on other boats. Usually what they do is make the threshold a separate piece so that the flex won't crack it. But that doesn't fix your problem. What I'd do is make a small "V" cut with a dremel then inject some MEK into the crack (this is capillary so it will seep in and weld everything together, it's also Weldon 4) then fill in the "V" cut with something that won't make it look so bad (I doubt that it will ever look fabolous). I would use Weldon 40 with a tint or perhaps tint some epoxy (remember when you tint and add some cabosil to double the catalyst or else it'll take days to kick) and at least you'll have something. Haven't heard of dichloramethane but I googled it an it said that rats in California are in some peril, but it is probably a capillary cement that should work.
AcryliCo is offline
Old 03-16-2005 | 12:54 PM
Stormrider's Avatar
Maybe I'll just leave them alone if that is the fix, especially if it won't dissappear. I can alway have another peice cut.
Thanks for the help.
BTW, the crack in the door molding is old, the one in the windshield... I can't remember if it was there last yr or not.
Old 03-17-2005 | 07:19 AM
AcryliCo's Avatar
If you ever want to redo that frame just send it to us and we'll do a new one!
AcryliCo is offline
Old 03-17-2005 | 07:51 AM
Stormrider's Avatar
Now that's what i call service!
Where are you guys located?
This may just have to wait till next winter though.
I also have a friend w/ a 28 magnum looking to do a new plexi windshield. Can you do this custom too?
And what would he need to send you?
