Mechanical Fuel Pump >
Old 03-16-2005 | 06:15 PM
Vinny P's Avatar
I hate the winter!!
Default Mechanical Fuel Pump
I am trying to help out a friend in setting up his fuel system for his new N.A. 540. He has a Gen V block with no provisions for mounting a mechanical fuel pump to the block. He will have to rely on his belt driven seawater pump to mount the pump. He has an electric pump which will be hooked up the usual way with the check valve but he wants a back up mechanical as well.
What pump are you guys running that will fit on the seawater pump and have a decent gallons per hour rate?
Vinny P is offline
Old 03-16-2005 | 06:20 PM
Michigan Mad Man
Default Re: Mechanical Fuel Pump
Hardin Marine makes a kit to update the stock pump.
TylerCrockett is offline
Old 03-16-2005 | 07:34 PM
I've got a Merc fuel pump, brand new in the box, that will fit that application. It was originally for my HP500 but is the same part number as that used all the way up to the supercharged 600hp engine. How's $100 sound?
JohnJan is offline
Old 03-16-2005 | 07:37 PM
Vinny P's Avatar
I hate the winter!!
As I said, it is not for my motor. I finished mine up a while ago, but I will pass on the information.
Vinny P is offline
Old 03-16-2005 | 09:41 PM
rbtnt's Avatar
I use the CV Products' billet pumps with extra valves on my 540 sea pumps.
rbtnt is offline
Old 03-17-2005 | 05:58 PM
Vinny P's Avatar
I hate the winter!!
Ttt
Vinny P is offline
Old 03-18-2005 | 06:54 PM
Cignificant's Avatar
If you have the Merc pump you can bolt that arm onto a Holley Marine Pump. Bolts right up..
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
BillR
27
08-10-2008 11:31 PM
greencard
10
02-12-2006 01:36 AM
Scott
7
07-05-2005 03:46 PM
johnkot
3
06-26-2004 10:25 AM
Kirch
3
07-08-2002 02:12 PM
