transmission shifter bracket
I am putting in two Huber cryptonite trannys and was needing some input on how to make up a shifting bracket, I assume it bolts on the back of the transmission? Any help and pictures would be appreciated. They are driveline models with a lots of room behind them.
I dont know if tou solved this yet but on one of my boats the cables are latched into the standard cable clamp like on a carb bracket that is mounted to the driveshaft cover housing. you could also make a plate off of yours if you have a setup like that.
My other boat has them coming from the opposite direction with a stand off bracket mounted to the side of the trans.
You can still use the stck setup if you can find an old tranny to scab the parts.
Hope it helps
Hope it helps
47 Lightning SE
47 Lightning SE
This is the best picture I can dig up at this late hour, and it was taken prior to cable installation, but all I did was take a piece of 304 stainless barstock, bend it 90 degrees, drill it for the transmission bolt, bolt or weld the Morse 33C bracket to it in the right spot, and you're on your way. You do end up with a bit of bend in the cable, but I used Supreme cable which can easily sustain the minimal bend, and it works like a champ! Mine is a plug-in so I couldn't go from behind. You have a lot more options available.
Originally Posted by open wide
Hey imonstaa, I think I met you at Key West at the Hilton pool. Are you from Long Island?
YES I AM. WAS THAT IN THE HOT TUB? Hope i wasnt a lil primed and offensive! just kiddin.
here is a pic from the bam website . this is a basically the linkage set up for borg warner trans .
http://www.mercruiserparts.com/Show_...+SHIFT+LINKAGE
