Crane HI-6M ignitiion question
I am thinking about buying the Crane HI-6M to replace the TB V on my 1998 HP500's that are now 620HP. Does anyone know if the merc knock sensor and module are compatable with the Crane ignition?
The Crane box has a brown wire that will activate the retard mode when grounded, the merc module also has a wire that goes from the knock module to the ignition module that triggers the retard. I am not sure if that trigger wire on the merc igniton grounds for retad or not, this is the same circut that you ground to set the timing on the TB V. Thanks in advance . Jeff
Just curious on the reason for the change? Rev limiter? Reason I'm asking is that I have thought of doing this myself.
I have Steps & Bubbles!
randy at cobra has them and the coils that go with. he also has a trick stainless bracket to mount the works. it really a clean set up even has a built in engine lifting ring. cranes wires are also great 25 ohms of resisitance per foot.
