Heavy-Duty Outdrive Stands
Old 03-18-2005 | 12:55 PM
CPPerformance's Avatar
Default Heavy-Duty Outdrive Stands
NEW - Heavy Duty Outdrive Stands For Mercruiser, Volvo & OMC
This stand was built to withstand the abuse of any boat shop or the home mechanic. Constructed from 1” square, 1/8” thick steel tubing and gas mig welded at every joint for the best possible bond. Heavy-duty swivel casters are mounted on all 4 corners making this unit easy to roll around the shop. Non-slip rubberized marine grade padding is added to the top rails for the drive to rest upon without scuffing. The stand measures 12W" x 24L" x 22H" with casters, and weighs 25 lbs.
In most cases this Drive Stand can help in the removal and or the installation of your outdrive (removal of the prop is required for this step). You can put your drive on this stand from the front or from the back of the stand. No need to flip your drive around on the stand. Most other stands on the market today you have to remove the drive from the stand and turn the drive around and replace the drive back onto the stand to perform work and do it all over again when you want to reinstall the drive.
You can perform maintenance on your drive with the drive stand on the ground or with the casters removed these stands can be bolted to your bench top for a more permanent repair station. When not in use these can be stacked for storage.
If your cavitation plate is at least 5 1/2" wide and the bottom of the lower drive to the cavitation plate is less than 20 inches this stand will work for you.
This is the best all around stand on the market today. Available powder coated black for superior corrosion resistance.
#525-2000 - Black $99.99
Order Online Here Today
CPPerformance is offline
Old 05-26-2006 | 07:49 PM
Default Re: Heavy-Duty Outdrive Stands
Now available to fit TRS Drives! (#6 pictured)
Old 05-28-2006 | 08:15 AM
GOODT's Avatar
now mind you Ive only been building drives for 25 yrs, but that DOES NOT look like a TRS to me ( could be wrong though its still early on a Sun morning )
Ilike these will be calling to order a couple though
GOODT is offline
Old 06-08-2006 | 08:01 PM
[CENTER]NEW - Heavy Duty Outdrive Stands For Mercruiser, Volvo & OMC
#525-2000 - Painted Black $89.95
#525-2005 - Powdercoated Red $125.00
#525-2010 - Powdercoated Blue $125.00
Order Online Here
#525-2000 is Powder Coated Black. Same price.
Also available for the#6 Drives
vette4jja is offline
Old 07-21-2006 | 03:45 PM
Don' take our word for what a great product this is. Check out what our customers have to say about it in our online product reviews:
MOST RECENT REVIEWS
William Bullock rated this item 5 out of 5
Great Product Well Made
Harry rated this item 5 out of 5
Excellent product, makes removing and working on my outdrive an easy and enjoyable job!
David rated this item 5 out of 5
Nice product. Purchased for home use and it makes it much easier to work on the out drive. I check the gimble bearing, check and grease u-joints and spline at least once a year. Stand holds well and makes the job much easier. Brava One. Thanks.
Old 11-24-2010 | 11:32 AM
New Link!!
http://www.cpperformance.com/p-14460...volvo-omc.aspx
prostock85
Wanted
0
09-19-2008 04:26 PM
chapp-sx
Drives and Lower Units
18
02-16-2008 06:10 PM
Pantera24
8
09-11-2006 10:20 PM
Jnewton
Prop Talk
4
05-11-2005 02:58 PM
