Marine Machine steering helm 3\4"?
I'm in the process of changing my steering hub i got a 3\4" hub, but it don't go all the way down on the steering shaft. their is about a 1\2'' gap between the hub & the steering helm. will a 7\8" hub fit better or be to big? this is a marine machine helm. im going with a 4" extenson.. i dont like this gap, anyone had any experance with this? thanks
if you have a 3/4 taper on a 7/8 taper, then you may end up with this problem. if it is could also be a safety issue. do you know the length of the hub adapter and the shaft size. also i'm sure bing from m&m can help .
If you are sure you have the correct hub for the shaft and it is seated properly you could make a 1/2'' spacer to go between the backside of the dash and the helm pump
its a rex marine 4'' ent. 3\4" taper... thats what i need to know is the mm helm a 7\8 or 3\4? taper.
the small adapter stem that goes between the actual helm pump and the back side ofthe, that protrudes through the actual dash board, comes in either 3/4 or 7/8. hence bing from marine machine can help. if not and you actually need a one off piece, give me a call. can probably make it for you. either way good lucki
Hardin Marine
New Products and Member Discounts
1
01-28-2008 06:47 PM
