Which to buy?
Old 03-19-2005 | 09:46 PM
MnFastBoat's Avatar
Charter Member#157
Default Which to buy?
Which ones of the following should I get?
Thinking more on the lines of the quick cleats, but the cost savings of the mushrom cleats is half the cost
They would ONLY be used for fenders. Looking at three per side.
anyone using either of these?
The mushroom cleats?
or the quick cleats?
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 03-19-2005 | 10:10 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
Default Re: Which to buy?
mushroom is my vote. I have had both and like the mushroom better.
mcraymond3 is offline
Old 03-19-2005 | 10:35 PM
hillbilly24's Avatar
the mushrooms actually work better, they have downward spring tension that holds the loop in your line better. you have to tie a knot to get em to stay on the quick cleets. I also like the look of the mushrooms better.
hillbilly24 is offline
Old 03-20-2005 | 06:32 AM
I have the quick cleats and like them alot. When they are not in use you can barely see the female portion on the boat. It looks like a thru hull fitting. The male end is permanently tied to the bumpers so, I just have to push them in when I need them. But, they are pricey.
BRET is offline
Old 03-20-2005 | 07:29 AM
MnFastBoat's Avatar
Charter Member#157
The quick cleats actually do sit FLUSH?
They look like it protrudes when not in use. Maybe its just the picture tha showes this
I like the idea of having the pin attatched. Always the same distance, fast and convenient to plug it in and go.
But for what I want to accomplish they are almost 500 bucks
Old 03-20-2005 | 10:19 AM
dykstra's Avatar
Mushroom
dykstra is offline
Old 03-20-2005 | 11:22 AM
SKRAMER's Avatar
I would buy the mushroom. I'll bet I could brake those other ones.
SKRAMER is offline
Old 03-20-2005 | 01:24 PM
Sea Ya's Avatar
Quick cleats. Tie the bumper once and you're done. Outerlimits have several.
Sea Ya is offline
Old 03-20-2005 | 01:26 PM
MnFastBoat's Avatar
Charter Member#157
Thats funny you say that
The mushrooms are out of aluminum and the quickcleats are stanless steel.
Old 03-20-2005 | 04:20 PM
Yea, the female side is basically a stainless thru hull fitting with a hollow threaded shaft and large washer and nut to sandwich it between the fiberglass. It lays flush when the pin is not inserted. I like the plug in and go also-tie them once and your done. I have 4; two on each side by the windscreen so I can plug them in quickly without leaving the helm and two on each side by the rear cleats.
I bought mine from Eddie Marine about $70,00 each.
I think they sell them in colors?
BRET is offline
