Cockpit Interior
Old 03-21-2005 | 05:16 AM
Try Me II
Default Cockpit Interior
Typically what should it cost to re-upholster / bolsters , bench, engine hatch??
Old 03-21-2005 | 06:47 AM
Semper Fi's Avatar
Default Re: Cockpit Interior
I think it will depend on the boat and who does it.
Semper Fi is offline
Old 03-21-2005 | 07:20 AM
Steve_H
i just spent 500.00 for an engine hatch and 500.00/bolster.
the padding in the bolsters were changed to make them more comfy. that added to the cost.
my engine hatch also had embroidery work to deal with.
Old 03-21-2005 | 08:08 AM
Boomer 880's Avatar
I spent $875 for an engine hatch and three headrests for a 40' Huslter. A lot depends on the size of the items, whether or not the wood needs replacement, and if you have any embroidery (logos) on the pieces.
Boomer 880 is offline
Old 03-21-2005 | 08:10 AM
Try Me II
$500 for both Bolsters
Old 03-21-2005 | 08:13 AM
Try Me II
My Brothers boat / 24' baja outlaw
Steve_H
i wish.
500.00 each
Old 03-21-2005 | 08:20 AM
Try Me II
i wish.
500.00 each
thanks
Old 03-21-2005 | 08:39 AM
lakeluvr's Avatar
www.sunriseuph.com
There are so many variables here there is no good way to tell. Of course the area you are in makes a big difference too. I can't speak from experience on your Baja, but most bolsters should run you $300-600 ea. Some like the McCleod bolsters would be even higher than that. Your hatch probably $400-700, altho I had a Baja hatch with alot of design in it that ran $850. And as mentioned there is no way to tell if the wood needs to be replaced which will make a difference too. Good luck.
John
Sunrise Upholstery
www.sunriseuph.com
lakeluvr is offline
Old 03-21-2005 | 03:34 PM
cig1988's Avatar
$4-$5000 soup to nuts. Not including carpentry work.
cig1988 is offline
