Flight is schedualed for Richmond, Virginia
Tuesday is the 5th
I might have to take the day off huh? Hotels won't be a problem, just depends on when your flights are and if you need to be close to the airport.
Boat should be 20-30 min. from the airport tops. I'm not sure which location it's at right now. The water is 15 minutes from either location. You won't have any rough water to run it in though. When we get closer check in with me...I'll PM you my number if you need anything.
Russ C.
I might have to take the day off huh? Hotels won't be a problem, just depends on when your flights are and if you need to be close to the airport. Boat should be 20-30 min. from the airport tops. I'm not sure which location it's at right now. The water is 15 minutes from either location. You won't have any rough water to run it in though. When we get closer check in with me...I'll PM you my number if you need anything.
Russ C.
I will always be around for a boat ride this time of year.
What boat are you looking at? I know pretty much everyone in this area. Do you know the owners name?
If the boat is in Pertersburg your are probably going to put in at Small Boat Harbour. Really close.
Give me a ring, could meet you.
James
804-539-3114
James
804-539-3114
James
804-539-3114
James
804-539-3114
Yes, I just saw the pics on the other thread, and regonized the boat. Very nice guy, cant get any better. The boat shows new, and very well maintained. Sonny Leonard motors in that thing are bullet proof.
Let me know, I WANT TO GO!!!!!
James
James
