PCV valve with supercharger >
Old 03-23-2005 | 09:21 PM
Default PCV valve with supercharger
Anybody running a pcv valve with a roots style supercharger?
It looks like the older merc 525 and 600 sc's used one that in mounted in the back of the intake manifold.
PROFILE is offline
Old 03-24-2005 | 08:26 AM
28SS's Avatar
Default Re: PCV valve with supercharger
The pcv valve would need to be before the supercharger . the intake will be pressurised
28SS is offline
Old 03-24-2005 | 11:36 AM
I would avoid using a PCV system on a SuperCharged engine. Any hot oil from the engine will run back through the supercharger, and can cause detonation.
RumRunner is offline
Old 03-24-2005 | 08:47 PM
Rummrunner,
Thanks for the reply. My motor blows a little oil out of the valve cover breather after I run it hard (extended periods of boost). I was considering running the pcv valve until I read your post. Never considered the hot oil causing det. but it makes sense. The last thing I want to do is make the air/ fuel charge any hotter. I might try to plumb the v/c breather to a "catch tank" of some sort.
PROFILE is offline
Old 03-25-2005 | 08:30 AM
Plumb the crankcase vent into the air cleaner. Use a automotive sponge like breather in the air cleaner to soak up any blowby oil. just change it out every few months. They're only a couple bucks and it will keep your engine compartment clean.
Gary Anderson is offline
Old 03-25-2005 | 02:18 PM
Mine has that pcv in the intake. I believe it is for the boost reference of the carb.
It does not go all the way through the intake.
Griff is offline
Old 03-25-2005 | 02:25 PM
KCHOTBOAT's Avatar
Charter Member #737
Griff
Is that what #2 is used for?
KCHOTBOAT is offline
alecsammy
0
05-27-2008 09:10 PM
ROB FREEMAN
10
07-18-2007 04:56 PM
miamioffshore
3
04-08-2006 10:42 AM
THRILLSEEKER
11-17-2003 07:22 PM
MIKE H
14
03-31-2003 07:08 AM
