Crane  HI-6M Multi-Spark Ignition >
Old 03-25-2005 | 10:33 AM
KCHOTBOAT's Avatar
Charter Member #737
Default Crane HI-6M Multi-Spark Ignition
Is it worth the expense. I am building a copy of a 525SC except bigger cam.
Crane Cams HI-6M Multi-Spark Marine Ignition
KCHOTBOAT is offline
Old 03-25-2005 | 11:47 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Default Re: Crane HI-6M Multi-Spark Ignition
I am adding acouple to my 500hp motors taht are at 565 hp
reason are programed ignition curve and adjustable rev limiter
klaw is offline
Old 03-25-2005 | 12:09 PM
Sean H's Avatar
A to Z
i have heard they are one of the best.... i will either get those or the msd ones..
Sean H is offline
Old 03-25-2005 | 12:32 PM
Built a 575 SC clone, I have been using the Crane for several years. Go with the Crane.
BadDog is offline
Old 03-25-2005 | 01:35 PM
KCHOTBOAT's Avatar
Charter Member #737
Thanks for the info. I will place my order tonight.
Old 03-25-2005 | 01:41 PM
Waterfoul's Avatar
Gone Fishin'
Been running one for years (except last year of course!) I like the dial in rev limiter. Using an MSD distributor with mine.
Waterfoul is offline
Old 03-25-2005 | 04:53 PM
KAAMA's Avatar
I have the MSD billet distributor with an MSD crank trigger system and use the Crane Hi-6M ignition box. I have had the Crane boxes for about 5 years now, and one got drenched with water sprayed on it from a hose that sprang a high pressure leak. I have only about 65 hours on them, but after 5 years they are still working fine.
KAAMA is offline
Old 03-25-2005 | 05:12 PM
DiamondPerformance's Avatar
Offshoreonly Advertiser
The nice thing about the Crane is, it plugs into the Merc distributor.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 03-28-2005 | 02:45 PM
I am about to order one for my Caddy 500.
I'm happy to see it is working well for everyone else.
27 sport is offline
Old 03-28-2005 | 03:23 PM
jamess4
I did mine last year - I remember having to redrill the rotor to "phase" the rotor for the Crane - no big deal and they give you the template to drill the new holes in the stock Merc rotor- only problem will be if you ever switch back to the OEM system you need to switch back to the OEM holes -
*** I purchased this set up so that I could also get the ignition retard set up with the box- probelm was the retard was not mfg by crane and I could not get one - I ended up just putting knock sensors on and ran with different fuel low and high octane to make sure the motor did not detonate -
fastlane40
08-09-2008 01:33 PM
DesertRage
9
02-02-2008 06:48 PM
DesertRage
Wanted
2
01-30-2008 09:52 AM
fastscarab22
1
11-05-2007 04:47 PM
Blue by You
17
05-11-2006 04:45 PM
