bbc rocker ratio question 1.7 vs 1.8
when 1.7 AND 1.8 rockers are run on bbc does the 1.7 go on the exhaust valve or the int? i have crane gold roller rockers how much play should there be on the pin to roller tip that rides on the valve? thx for info. ratman
Just depends on what you are trying to acheive, which one are you trying to improve. Might want to make sure the extra lift doesn't bottom out your springs, or cause the valve to hit a piston.
or put the bottom of the retainer/locks into the top of the stem seal.
THere's no rule of thumb.
Whichever side is your weak side gets the additional lift. Optimally, your cam will be staggered to fit your application, but the rockers give you tweak-ability.
the motors are 577ci n/a's with big brodie heads, flat top je pistons. there were crane 139741 cams in the motors i stepped it up to a 139661 crane hyd roller.741 was 234/242 @ .050 vs 256/264 @ .050 741 is 610 int/632 ex vs 661 632/632 lift. where would you run the 1.8's? and why? thanks, ratman
#1) The 1.8's will put your lift up to .670" which means a different spring setup.
#2) "plenty" of piston to valve will STILL need to be rechecked during assy.
which heads? as-cast 305cc? or cnc 325's?
What exhaust you running? Dry or wet? Mufflers?
My gut is to stick with 1.7's on both. No new spring issues, pushrod length issues... If you just HAVE to run the 1.8's, then I sorta think you should put them on the intake side. If you run mufflers or wet headers, then maybe put them on the exhaust side.
that's my thoughts.
that's my thoughts.
I agree with mcollins and would not run them in this application. You have plenty of cam for the motor and will not likely see any gain from the 1.8's not to mention other issues mentioned above.
A 741 is a split pattern cam that favors the exhaust to make up for deficiencies in the GM heads. Your Brodix heads are running a heavily improved exhaust port, so your new cam choice while still a split duration cam, has equal lift on both sides. This is a good thing for your heads.
I bought a motor once that came with an edelbrock SP2P intake on it, a 1.5" open phenolic carb spacer, and a 780 Holley with stiff springs in the secondary vacuum pot. Just cause it came that way doesn't mean that it was a good setup (I may still have that crap in storage somewhere if you want to try it)...
