98 502 mag efi runs with key off >
Old 03-28-2005 | 05:38 AM
Enticer Rick's Avatar
From: Lake St Clair Metropark, Harrison Township, MI
Default 98 502 mag efi runs with key off
I have a 98 502 mag efi that sometimes will stay running after turning off the key. I have pulled the safety lanyard and still no luck. I have had to pull the coil wire to shut it down. This only happens once in a while, I checked for loose connections but still no luck does anyone have any sugestions or is this thing haunted any feedback would be helpful.
Enticer Rick is offline
Old 03-28-2005 | 05:57 AM
Default Re: 98 502 mag efi runs with key off
If it were a 1968 loaded with hours and crud and using cheap gas then I would say it is dieseling, but with such a new engine it is probably something in that crazy EFI system.
Pismo10 is offline
Old 03-28-2005 | 06:48 AM
excursion's Avatar
Might want to check the ignition switch for corrosion build up. If the contacts in the switch still make contact could keep the motor running.
excursion is offline
Old 03-28-2005 | 09:49 AM
Dave_N's Avatar
Sounds like it could be a sticking ignition power relay. Next to the ECM there are two relays. One is the fuel pump relay and the other is the ignition relay. The ignition relay has two red, one pink and one black wire. Next time it happens, check the pink wire for 12V. If there is power there, the problem is the ignition switch, if not it's the relay. Maybe try tapping on the relay to see if it releases.
Dave
Dave_N is offline
Old 03-29-2005 | 05:35 AM
Dave,
That sounds like it could be the culperate, hopefully I will be splashing in a couple of weeks and i'ii check it out. Thanks for your help.
Old 03-29-2005 | 07:30 AM
boatn70's Avatar
even if it was in the ignition switch wouldnt/shouldnt the lanyard kill it? i would think so.....
boatn70 is offline
Old 03-29-2005 | 08:28 AM
Dave_N's Avatar
boatn70,
You are right, if it were the ignition switch, pulling the lanyard would kill the engine. Pretty much has to be the relay.
Dave
Dave_N is offline
Old 04-01-2005 | 04:43 PM
What was the final story here, what was the problem?
Pismo10 is offline
Old 04-02-2005 | 06:41 AM
Pismo,
Because of the beautiful michigan weather I have not been able to get the bottom wet. hopefully in a couple of weeks I'll be able to give you guys an answer.
Old 04-02-2005 | 09:47 AM
i had the same problem, the alt. was bad, the alt. was shorting out and the batt. was keeping juice to engine so you could not shut it off.
Velociraptor is offline
