JC Perf. Said I Need Diapers >
Old 03-28-2005 | 07:28 PM
Strip Poker 388's Avatar
Rob
Default JC Perf. Said I Need Diapers
I told him just because his bottom end is bigger than mine I still don't need them.
I guess we will see next week Maybe they want poke a hole thru that carbon fiber in my hull.
Jeff they didn't have your color.Does that kevlar itch when you put them on?
Strip Poker 388 is offline
Old 03-28-2005 | 07:56 PM
Default Re: JC Perf. Said I Need Diapers
thatill hold alot of ham
open87 is offline
Old 03-28-2005 | 09:19 PM
JCPERF's Avatar
That will hold his connecting rods on the dyno.
JCPERF is offline
Old 03-29-2005 | 01:47 AM
Rob
Rod bolt soup with chocolate milk
Old 03-29-2005 | 08:16 AM
JCPERF's Avatar
You saying you ground the heads into water?
JCPERF is offline
Old 03-29-2005 | 08:34 AM
So Rob when you pulling the pin on those grenades?
amarket1 is offline
Old 03-29-2005 | 08:58 AM
Rob
Trying to go to Precision Marine next week.
Just ordered 28ft of #12 for the innercoolers.It may blow up but atleast it will look good .I am running out of time for the Tickfaw 200 Poker Run .
Sean what did the 1200+hp motor sound like last week? Mark said you could hear it from your office
Rob
Old 03-29-2005 | 10:04 AM
It sounded bad A$$.That thing sounds completly diffrent than any other motor I have ever heard on the dyno.I tell you what that old guy that owns that boat has some huge balls.1247hp in a 22ft Cat.
amarket1 is offline
P Offshore
06-19-2006 04:45 AM
masher44
04-02-2006 09:11 PM
