Graphics software
Old 03-30-2005 | 01:07 AM
DirtyMoney's Avatar
Default Graphics software
Are there any programs that have standard hull designs to play with color schemes???
DirtyMoney is offline
Old 03-30-2005 | 02:45 AM
Default Re: Graphics software
an extremely good question!????
SUNSATION 25 is offline
Old 03-30-2005 | 06:25 AM
scottc's Avatar
I sure could use it also
scottc is offline
Old 03-30-2005 | 06:44 AM
glassdave's Avatar
Neno the mind boggler
dont think there is any standard software for things like that. i use Corel10 for my graphics and all of my templates are custom. what kind of hull style do you need. i may be able to convert them into a different type of file that you can open in Word or somthing but you would have to do your graphics the old fasion way ( pencil ) i think there was a thread a few weeks ago on this, you may want to do a search. i lost treck of it so i dont know if any thing came of it.
08 OPA High Points Champion
glassdave is offline
Old 03-30-2005 | 07:17 AM
dtsquest's Avatar
You could go to a few of the manufacturers websites to choose different color schemes, them customize them to you likings. Sunsation has a good site to view different graffic packages.
dtsquest is offline
Old 03-30-2005 | 07:27 AM
jayboat's Avatar
CorelDraw and Adobe Illustrator are probably your best choices, but both have fairly steep learning curves. I assume you mainly want some semi-accurate way to visualize possible new color schemes for your boat, so unless you intend to get into the graphics biz, Dave's suggestion would be mine as well. An easy way to make your own templates would be to print photos, trace the contours on tracing paper, and then scan or make copies. It's difficult to draw with a mouse, and unless you have a graphics tablet, a set of colored pencils would be an easier method.
Roostertail does not lie.
NAPLES IMAGE Photo Galleries
jayboat is offline
Old 03-30-2005 | 10:06 AM
kcgbjc's Avatar
Charter Member # 430
I used Illustrator. It worked well for me. But you have to know what you are doing, which is true about any software you will try to use. I suggest to go to a good designer. Some will cost less the than the cost of the software.
I have used http://www.rr-custompaintworks.com/. Randy is on Discovery Channel all the time and has some awesome ideas.
Chris Johnson
Armed Forces Racing
www.armedforcesracing.com
kcgbjc is offline
CAP071
11-22-2004 08:07 AM
Wardey
01-24-2003 09:26 PM
klaw
08-09-2002 07:12 PM
