Hyd. Roller Lifters >
Hyd. Roller Lifters
Hyd. Roller Lifters
Old 03-30-2005 | 07:52 PM
lukiepal's Avatar
Default Hyd. Roller Lifters
I am changing out my cam that has hyd. roller lifters with about 10 hours on both lifters and cam, can I install the new cam with the old (10 hours) hyd. roller lifters?
lukiepal is offline
Old 03-30-2005 | 07:58 PM
born2burn's Avatar
Default Re: Hyd. Roller Lifters
I have been told and the way that I understand it is to always start with a new set of lifters with a new cam. Even though your current lifters only have 10 hrs. on them they have a wear pattern on them from your current cam. If you put your already broke in wear pattern lifters with your new cam you have a potential of prematurely wearing in a bad pattern in the new cam lobes causing it to go flat.
born2burn is offline
Old 03-31-2005 | 07:59 AM
Yes you will be fine with using the old lifters as long as the cam has no more then .360" lobe lift. The OEM "dog bone" type lifter is limited to that lift due to design.
Chris
cstraub is offline
Old 03-31-2005 | 04:51 PM
lukiepal's Avatar
Thanks again
lukiepal is offline
Old 04-03-2005 | 09:19 PM
Jmemoli's Avatar
Goumada P5-38
Lukie ,
Rollers can be resued as long as their in good condition .
flat tappets can never be reused .
Jmemoli is offline
ratman
28
02-06-2007 08:34 AM
KCHOTBOAT
45
08-26-2005 10:48 AM
RickR
9
08-20-2003 07:34 AM
paradigm shift
12
08-01-2003 10:30 PM
ASD-6
4
01-10-2003 03:20 PM
