1 or 2 coats of wax?
Old 04-01-2005 | 09:54 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default 1 or 2 coats of wax?
Ok, so what's the general opinion since it is that time for the 1st shine job.
If you could have someone else do it so labor is not an issue...
1 coat plenty, but 2 better.
Or 2 coats no added protection and even make for wax build up?
And along those lines, is there really a difference between auto wax and boat wax, providing both are carnuba waxes with UV protectant?
US1 Fountain is offline
Old 04-01-2005 | 10:59 PM
Outdrive1's Avatar
Masher touches my
Default Re: 1 or 2 coats of wax?
It would be easy to get taken if you aren't watching to make sure they wax it twice. I think one good coat should be sufficient, if you have some issues with your paint then maybe you should pay to have it buffed first and then hand waxed. Either way I use whatever Meguires is the the most expensive at the auto parts store when I go to buy wax. Usually a premium carnuba wax. I also apply it in sections and wipe it off before it dries, I dont know why but I was told by a detailer once not to let wax dry on your paint first. That was back when I was taking my 69 GTO to car shows all over. Maybe someone else will have some input on the drying factor?
Outdrive1 is offline
Old 04-02-2005 | 06:10 AM
offshoredrillin's Avatar
Has anyone tried Zaino bros polymer on their boat. Being in the business I see what it does for cars, just want to know if anyone has put it on their boat?
www.zainobros.com
offshoredrillin is offline
Old 04-02-2005 | 06:23 AM
The Menace's Avatar
Polymer is better than wax. It is not so susceptible to detergents or the weather.
In fact, a good polishing is better than a wax. A polish will actually remove all the surface grime and polish the fine scratches out of the paint. Then apply your polymer for protection.
The Menace is offline
Old 04-02-2005 | 07:01 AM
traviss's Avatar
I just got my order of zaino bros polish. They recommend the Z-3 polish with the ZFX activator. No need to wax after the polish, they said that this polsih will protect better then any other wax you could use. I will be cleanin up my boat soon.
traviss is offline
Old 04-02-2005 | 07:08 AM
Formula Outlaw's Avatar
I've had good luck using Meguiar's "cleaner/wax" first, LIGHTLY going over the painted surfaces, then their "Premium Marine Wax".
Always open to new ideas though. It's a lot of work.
Formula Outlaw is offline
Old 04-02-2005 | 07:14 AM
AMERICAN BAD A$$'s Avatar
I always hit mine with Finesse-it 2 using a black foam pad on the buffer , then by hand with Eagle One Nano wax. No matter how perfect you think your finish is , Finesse-It on the foam pad will make it look better every time . We wet sand and buff everything we paint no matter how good it looks out of the booth . Oh and thanks to the $hitty weather keeping me off of the lake , my Fountain has about 12 coats of wax .
AMERICAN BAD A$$ is offline
Old 04-02-2005 | 07:25 AM
Originally Posted by sutphen30
i use the collanite(sp) products.first the cleaner then 2 coats of wax for the gel coat.1 coat for paint.then i use a car wash with wax in it for after boating day clean up.of course someone gives me a small sample of the z brothers stuff,,i'll give an unbiased report.
Well "stuphen" , I think if you hit the site they will send out samples. I know lots of car guys that use it and was wondering about boats, I think once I have the paint work done on the Tiger, I'm going to try the Zaino, I know it goes on like a dream.
Old 04-02-2005 | 07:30 AM
t500hps's Avatar
21 and 42 footers
Just used the same stuff. Looks like the second coat was necessary. Almost like the first coat "soaked" into the gelcoat.
t500hps is offline
Old 04-02-2005 | 02:24 PM
Tricky919's Avatar
two coats Biff..........
Tricky919 is offline
