Tow rig?????
Old 04-04-2005 | 09:41 AM
Registered User
Default Tow rig?????
I was looking at a 98 1 ton chevy with a big block low miles and perfect. I was wondering if anyone new the torque specs on the vortec 454? And how do they pull? Thanks Guys.
320es is offline
Old 04-04-2005 | 10:00 AM
RHICKOFF's Avatar
Default Re: Tow rig?????
What are you looking at towing. I have a friend that's towed a 35' Cig. it fried his tranny. Not sure what gears he was running.
RHICKOFF is offline
Old 04-04-2005 | 10:40 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Its a nice truck. Shoot a PM to Aggressor 25 here on OSO. He is selling his 1998 3/4 ton Suburban with the same engine. He has 108,000 on his. He knows the ins and outs of that power package well.
Sydwayz is offline
Old 04-04-2005 | 06:14 PM
Tim G.'s Avatar
Performance Boat Center
I had an '00, which was the same truck....K3500 Crew Dually 4x4, 454 auto.
Good truck...
The tranny went out of it at 3,500 miles...by fault of the dealer..
The good ole boys in SC fixed it up, and it never had an issue after that. I put 70k on it, then traded on my D max.
I'd say the worst thing about the truck was the brakes. NFG. The new style trucks stop much better.
The rear brakes almost never did anything...
That truck rode great once I put decent shocks on it.
I put the Banks powerpack on it... It woke it up quite a bit up top. I believe the stock torque figures were about 450lb/ft. Stock HP is 295.
I got 11mpgs constantly when empty (but I have a heavy foot), got constant 9-10 pulling 8,000. It'll pull in top gear at 80mph no problem.
Heaviest load I pulled was a Tiger on steel trailer, AND two 900 Sterlings in the bed of the truck. No brakes on the trailer!
That trip actually finished off one of my front tires (from braking). Power with that load was decent.
Aggressor's Sub wouldn't be a bad buy at all.
The 4L80E tranny is TOUGH. I wasn't easy on that truck... My '94 had the same trans and got beaten on a daily basis. Never an issue.
Need more info? Ask away..
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 04-04-2005 | 08:01 PM
'05 Concept SF23
I tow a 43' Black Thunder @ 14K lbs with a '97 C3500 crew cab dually. 10-12 mpg empty. 7-10 towing. Brakes "NFG". Put a different master cyl and porprotioning valve, big improvement. Also installed an alum. rear end cover that holds 2 extra quarts of lube. Don't burn paint off the cover any more. Joe Murray
f311fr1 is offline
Old 04-04-2005 | 09:17 PM
Sean H's Avatar
A to Z
Good truck...
you wouldn't still have those sterlings would ya?
Sean H is offline
Old 04-04-2005 | 09:53 PM
Tim G.'s Avatar
Well they were National Marine's... No they were the new owner's, no..they were the "prior" owner's....
So, even if I still had them...they'd belong to someone else...
Tim Gallagher
[email protected]
954-809-8739
Tim G. is offline
Old 04-05-2005 | 06:57 AM
t500hps's Avatar
21 and 42 footers
I believe Craig223's suburban had that motor too...
t500hps is offline
Old 04-05-2005 | 08:35 AM
Registered User
I have a baja 320 with a borrowed steel trailer right now boat weighs 7500 empty. I went ahead and bought the truck, it is probably cleanest truck I have ever seen of that age. I has had royal purple in everything since new. The owner told me the same thing about the brakes, he had the rotors cryogenicaly treated to help keep them from warping. I had a 85 1 ton and it had awesome brakes, hydroboost factory. I am suprised they downgraded.
320es is offline
Old 04-12-2005 | 03:08 PM
dykstra's Avatar
410 stock
dykstra is offline
JasonSmith
Baja
16
04-11-2008 08:50 AM
Ca$hed Out
06-12-2006 09:31 PM
vagrant
12-18-2004 10:21 PM
buck183
08-15-2003 08:05 AM
