Need help getting Throttle controls off >
Old 04-05-2005 | 10:50 AM
WHOSNEXT's Avatar
Default Need help getting Throttle controls off
I have a 25 outlaw with stock controls. How hard is it to take them off? I think there is 2 wires and 2 cables? Any help would be appreciated.
WHOSNEXT is offline
Old 04-05-2005 | 11:43 AM
Default Re: Need help getting Throttle controls off
It shouldnt be too hard. The two wires should be for the neutral safety switch. If you can trace them and disconnect without cutting, obviously that would be best. The cables should be self explanatory. What type of controls are you removing?
TxHawk is offline
Old 04-05-2005 | 01:00 PM
hillbilly24's Avatar
it is best to unhooh the wires without cutting them but its pbobable not possible unless the boat builder put bullet connectors in. they ussualy just butt connect them though and then those wires just tie in to the main harness. when youa re hooking them back up it doent matter wich way they get hooked up though becuase it is just a disconect switch.
hillbilly24 is offline
Old 04-05-2005 | 06:57 PM
ChristianGott's Avatar
like anything else...go slow....
the wires are easy, as stated by hillbilly.....
just check to be sure which is the shift, and which is the throttle before you disconnect..
i have twins, recently switched to gaffrig...and i actually used a sharpie to write directly on each cable....the whole process, with the cutting of the dash....was real easy.
c
ChristianGott is offline
CAPTAIN CHUCK
Wanted
4
03-21-2008 12:28 PM
288sunny
Baja
5
06-16-2007 04:26 PM
288sunny
Sunsation
0
06-12-2007 08:51 PM
nordic95
6
10-15-2006 08:59 PM
HiPerf2000
5
08-26-2004 08:44 PM
