-   Skater (https://www.offshoreonly.com/forums/skater-42/)
-   -   28 Skater vs 30 Motion (https://www.offshoreonly.com/forums/skater/114653-28-skater-vs-30-motion.html)
Sean H 10-20-2005 11:09 AM
Re: 28 Skater vs 30 Motion
Originally Posted by mmwalters
As in 3500lbs? If my ever fading memory is correct The min. race weight for a 28' is 3800lbs a 30' hull needs to weigh in at 4200lb and a 32' is 4400lbs.
To me that makes those Doug Wright 32' very impressive as Ryan B. and crew ran over 116mph in Tenn last weekend
i believe they add weight to the race boats....
mmwalters 10-20-2005 12:23 PM
Sean I believe you are correct.
The mininum weights were put in place to encourage builders to use enough fiberglass to keep the boats from breaking in half after the 1st wave.
I have heard as lite as 3300-3400lbs for a 28' with 2.5s
Sean H 10-20-2005 12:36 PM
all that encourages is to build the boats as light as possible so they can put weight where they want it later...
Ryan Beckley 10-21-2005 05:16 PM
28=3800
30=4050
32=4300
race weights
mmwalters 10-22-2005 11:35 AM
Originally Posted by Ryan Beckley
28=3800
30=4050
32=4300
race weights
I stand corrected
Thanks Ryan
Ryan Beckley 10-22-2005 01:53 PM
A Motion is a great design overall and will run with the other similar designs, Spectre and AMT. But you can't compare these to a 28' Skater it is kinda like comparing............um........I dunno , but they are different OK? Yes the 28 IS faster, ALOT FASTER in some cases, but for the most part all are good boats.
mmwalters 10-22-2005 02:23 PM
Ryan what are your expectations on the new 32' skater compared to what is currently racing? Are the boats being built for ss the wide beam hulls? The Doug Wright 32' seems to clearly be the class of the field now.
offshoresteve 10-23-2005 11:09 PM
Well said Ryan.I need to talk to you about updating the graphics on my 28.
dreamboater 10-25-2005 07:05 AM
Michael, I am with you. The 32 Doug Wright is very impressive with both speed and handeling in rough water. I would love to have a pleasure built 32 Doug Wright. Has anyone ordered one of these boats with open canopy and either 2.5's or X's
Ryan Beckley 10-25-2005 07:42 PM
The Doug Wright is awsome, I would have never believed the speeds until I did it. The new Skaters 30 and 32 are going to be trick . Pete is very serious about taking back his outboard business.
