you know guys just because the boat is being built at skater it may not be a skater a ha
Outerlimits is picking up where fountain left off. Fountain had a 2' beak well OL has a 3' swim platform.
Originally Posted by 24skaterVA
(Post 2997689)
Cig actually did came close and had plenty of power to do so but did not make it due to the problem with re-entering the water @ over 170. At those speeds there was no more hull left in the water, just the lower 30% or so of the Props and the skegs.
JT said it was "like balancing a bowling ball on a knife", which meant(as I understand it) the sharp keel at the transom was the problem, unlike the Fountain which had a pad bottom to run flat on. |
Originally Posted by JIMKID Motorsports
(Post 2996896)
5 Attachment(s)
Originally Posted by Catmando
(Post 2998180)
Braver says if he wants a boat built with Epoxy/Kevlar/Carbon he lets Skater build it. Peter built the Kilo boat. Cigarette uses conventional materials which means heavier boats. Hell I'm not even sure they vacuum bag.
That's going to be one sweet boat for sure!
Is it going to be a Cig or Skater? If its a Skater, why would Pefer use use the Cig bottom instead of his own design....? Thought Skater never copies/uses other manufactures design and innovates not imitates...... |
Originally Posted by lavey jr
(Post 2998260)
he probably started with the 46' |
Originally Posted by ziggy
(Post 2998306)
correct, the late cigs(50'marauder,46'XP and 49' grand sport) were designed by Peter.
(Post 2998306)
| All times are GMT -5. The time now is 08:28 AM. |
