Skater 36 v. Motion 35
Any opinions on which is better boat
Originally Posted by Excess
(Post 3278161)
Motion is closer to 32 Skater A
I have owned a 35 Motion. The 35 Motion is a basically a stretched and widened 32 Skater. The 35 Motion is a great boat, however the 36 Skater is a much larger deeper hull. The Skater is really no comparison to the Motion. The Skater build quality is better, resale value is better and rough water ability is much better. I am not knocking the Motion at all. I would not hesitate owning another 35. But you asked about the two compared. The 36 is a lot bigger boat when parked side by side with a 35 Motion. It will also cost more.
SKATER.
Enough said. |
wow,, someone actually asked which is better?
The 32a, Motion, and Spectre are all a little fine in the frontal area and are more prone to stuffing. The 36 Skater not only has a deeper tunnel, it also has more frontal area in the forward sponsons. For these reasons, the 36 Skater can run harder and faster in bigger water.
The motion's and Spectre's typically have 500 - 600 hp engines and run Bravo based drives, while the 36 Skater's typically have bigger power and 6's. Now with that said. It's not really far to compare the Motion and Spectre to the 36 Skater since they aren't even close to being in the same $$$ ballpark. Comparing like condition and year, the 36 Skater will typically cost about 2 or 3 times as much... |
Originally Posted by lavey jr
(Post 3278300)
SKATER.
Enough said. |
Skater!!!
(Post 3278300)
SKATER.
Enough said. |
| All times are GMT -5. The time now is 03:16 AM. |
