28 Skater boat lift
Anyone have information on hydraulic boat lifts that will for sure fit a 28 Skater? This type of lift, but fit for a 28 Skater... http://www.sunstreamcorp.com/Sunlift.htm
All they do is widen the bunks, raise the front a tad higher than the rear to compensate for the angled tunnel and make the supports taller. Thats about it. Everything else is the exact same.
Originally Posted by skaterator
(Post 3529944)
Not sure where you are located but we have a cradle for sale that was utilized for a 32' Skater. It is galvanized which is a ladder style with cross bars to tie the two ladders together.
I can send you a photos if you provide me with an email address. Thanks, Fred Allstar Marine Cradle is located near Baltimore, Maryland |
craddle
allstar im interested in craddle call me @ 631-872-0995 thanks jeff
I'm still struggling to find a hydraulic lift that will work with a 28' Skater without a lot of structural modification. I'm still running into the same problem where the beams that hold the bunks are too wide for the tunnel. Anyone out there using a hydraulic lift with your 28'?
Just skimming through some old threads and thought I should have some opinions on a proper lift for a 28 or 32 Skater. I use a Boathoist USA cradle for my Scarab but straps would work fine. I'll be sharing this slip sometimes with a Skater or other cat. Can I lift a 28-32 Cat using straps under the sponsons without any problems longterm. TIA.
My skater came with a hydraulic Naylor lift.
| All times are GMT -5. The time now is 01:01 PM. |
