Intercooler plumbing
I am adding intercooers to my Skater this year and rebuilding my 540s. My question is what is the bet way to run the water thru the cooler. I have hardin seastrainer that run to a water pump with impeller. Do I splice into that system or ? What the best way of feeding the coolers the waste is easy I think
Originally Posted by mrdwp
(Post 3666330)
Why? You don't want to run water thru them continually? I have seen some boats with water running out the side at the dock.
(Post 3666374)
Originally Posted by catinaround
(Post 3666381)
That would be out the motor, the IC with water at idle will lead to puddling and rich conditions .The best way is to have a pick up on the back of the boat that is forced feed just for the IC and it's own sea strainer. You do not want to rob any water that the motor needs for cooling. And you really do not need to run water in the IC at idle or low speeds. This is what I have learned and found to be the best set up for a IC.
Interesting. Anybody else out there have some tips or best practices?
How do you flush the intercooers after use. Need to do that where I go
| All times are GMT -5. The time now is 06:23 PM. |
