-   Skater (https://www.offshoreonly.com/forums/skater-42/)
-   -   attaching a race hatch (https://www.offshoreonly.com/forums/skater/276497-attaching-race-hatch.html)
LAriverratt 05-15-2012 08:01 AM
any of you guys have any pics of race hatch hardware that is being used? I want to be able to install and remove it fairly easily if at all possible.
LAriverratt 05-15-2012 12:26 PM
d4mn...39 views and no opinions, input, suggestions or anything??? you really can tell summer is pretty much here can't ya!!!!!:party-smiley-004::lolhit::lolhit:
noli 05-15-2012 01:12 PM
3 Attachment(s)
Not sure if this application would work on yours, but maybe you can come up with some idea similar to his.
Larry would def sell you these under-the hatch and hidden stainless hinges. If you can use his design, I'm sure Larry would sell you a few.
I believe the quick-release pin is hidden under the hatch, Larry would need to elaborate on this.
http://www.offshoreonly.com/forums/s...ter-hatch.html
LAriverratt 05-15-2012 01:52 PM
looks good. that may work. I have the older style rear seating without the storage compartment (seating is all the way to the stern) that's why I want to be able to take it off completely without a lot of b!thing and knuckle busting.
skate 05-15-2012 02:52 PM
My old 24' was rigged with hinges on the race hatch at the stern. It had cables attached to limit rear opening preventing the hatch from hitting the motors. There were two 2x4" 1/4" aluminum brackets mounted to the inside of the gunnel with a half inch hole drilled into the center of each. The underside of the race hatch had hood/deck pins attached which inserted thru the aluminum brackets. We then pinned the hood clips to secure the hatch. Neoprene was used to cushion between the hactch and bracket. Sorry no photos hope you can understand the description.
It closed over the seat.
Spiderman 05-15-2012 06:17 PM
la.....skate is correct .... however, if i were you give pete a call at skater...he has all the best stuff to help you out........he knows best
offshoresteve 05-15-2012 10:17 PM
Chris, I will never forget you hooking me up with all new polished hardware when I was at the factory......Thanks Again Buddy!!!
LAriverratt 05-16-2012 07:37 AM
thanks for the info guys. My 28 will acctully be in Douglas MI soon so I'll talk to Peter about it for sure.
LAriverratt 05-17-2012 07:06 AM
looked at the hatch real good yesterday...it still has the pin shafts on it along with the cables. looks to have had hinges that bolted on the top of the hull vs a hidden style so that I'll have to change along with adding the "wing" plates to the hull with the neoprene cushions.
skate 05-17-2012 10:32 PM
That's it. But if you change to hidden hinges it may prevent you from leaving the rear seat in the boat. Good luck Skater brother!
