-   Skater (https://www.offshoreonly.com/forums/skater-42/)
-   -   Gel coat repair (https://www.offshoreonly.com/forums/skater/286103-gel-coat-repair.html)
mrdwp 10-08-2012 07:06 PM
Gel coat repair
So my 2000 36 skater needs the bottom of the hull repaired. The gel coat is falling off in areas. Partly from the hall in and out and partly from just 12 years of use etc. is this a common problem? What is the proper repair process. I don't see any fiberglass problems but te gel coat is in need
