New 318 Flatdeck Widebody Outboard build.
I had to go up and register.........until I was told I was banned. Lol.......... It didn't matter to me though, I took my 28 on the run the next day.
I don't think Bob knew it was me on the run the entire time in my 28 until the last stop. He was on the lookout for my 30 on Saturday, he didn't know about my 28!
Registered User
Thanx everyone for all the input. I like the idea of moving the bulkheads for more room. Being that the boat was already under construction when I took it over I don't have a lot of options there. From the pics Ive seen the bulkheads are already in place. As far as the CG goes Ill have to trust that Pete gets that right. Sounds like it may be able to be corrected by these ballast tanks you speak of. Ill have to bring that to there attention as it sounds like they should be installed during the build. Im sure the rear one could be done later. Where would one up front go and is it necessary. Sounds like I should be more concerned about being front heavy because of the windshield situation. Thanx Steve. Leave for NJ tomorrow. Pics will come shortly. Nothing great yet just open hull.
There is not much room between the front and rear seats on the 308. I would have Pete move the rear seat bulkhead back 6" and dash bulkhead and dash forward 6". This will give you some room to get around between the seats. Also have the foot rest movable or custom placed so you can reach it to brace while running. I would set up dual trim and Jack plate controls with lock out so you can throttle and let someone drive. Watch placement of the steering wheel sometimes it is mounted too low on the dash. I would recommend going to Douglas and sitting in the boat and having them custom set up foot rest steering and gauges.
Hydraulic Jackplates are the bomb. You also may want to consider thru hull pickups as when you get the motors up on the plates and running hard the water pressure becomes an issue even with the water ramps in the hull. Pop up dictators are much easier to read than the mercury racing vessel view. Also my 308 is very light in the bow. I would consider moving the batteries in front and tanks forward.
Twin 300XS are going to max out at 100-102. Trips or something "stronger" would make it more fun.
Make sure they put fender pins on the deck also.
Congrats on your build you are going to love the boat.
Registered User
Hey LA, Not sure how many 308 flat deck wide body boats have been built before this. I know not many. Haven't been able to confirm that info. You have any idea how many are out there? Steve.
lol
