-   Skater (https://www.offshoreonly.com/forums/skater-42/)
-   -   Maybe a Real Octane Booster! (https://www.offshoreonly.com/forums/skater/333893-maybe-real-octane-booster.html)
Taboma 01-19-2016 02:03 PM
I have been looking for a real, viable gasoline additive that I can use in my 300SX's to supplement our only 91 octane (R+M/2), non-leaded, non-ethanol gas available in Oklahoma to get to 93 (R+M/2) . I have researched most octane additives currently out there. All, in my opinion fall short. They state they can raise pump gas by "x" points of octane. Note that a point of octane is only 1/10 of an octane rating number in R+M/2 rating. So, 10 "points" only raises our 91 to 92 octane! Don't believe it just read the 'fine print" on the current offerings! Looks like the below link is the real deal! Anybody try this stuff yet?
http://race-gas.com/
F-2 Speedy 01-19-2016 02:17 PM
I didn't read it all, 32oz treats how many gallons
Drock78 01-19-2016 04:19 PM
check out boostane
Quinlan 01-19-2016 04:43 PM
Splash some 110 it smells So good!
Double Rigged 01-19-2016 04:48 PM
David
I agree check out Boostane. Also the guys on S&F have been running a product called ACES. I have used it for years with no issues. One ounce treats 6 gallons.
Chris Carson and DBR both 2 stroke engine builders have tested it and said it works. It really does not increase octane but lower the combustion temp.
I can get you the number and you can speak wth him about. I do not remember all the details as it was a long time ago when I spoke to him.
Flightplan 01-19-2016 05:04 PM
RACE GAS
BLENDING CALCULATOR
2 OUNCES OF RACE GAS
WILL RAISE THE OCTANE OF 1 GALLON OF GASOLINE
4 FULL OCTANE NUMBERS (40 POINTS OF OCTANE).
Use the calculator below to determine the appropriate
amount of Race Gas to add per gallon:
1 - GALLON FUEL
Taboma 01-19-2016 05:29 PM
Originally Posted by Drock78 (Post 4395244)
check out boostane
Some testing that my shed some light on the snake oil. I believe the ACES IV is a good product to enhance the characteristics of gasoline and I do use it.
https://www.youtube.com/watch?v=2jbc...layer_embedded
http://members.rennlist.com/951_race...omparison.html
1989mach1 01-19-2016 07:46 PM
I thought about doing this but wasn't sure if it would be safe for my 500efi's. I use to run it in my motorcycle. And if it is ok what do u do like one gallon to a tank full.
class6 01-19-2016 08:53 PM
VP C5 booster you get 3.3 double it and you can get to 8.0 But you will need a lot of timing to make it burn. not sure if its worth the retuning
CIG3 01-20-2016 07:03 AM
2 ounces per gallon
gets you 4 points.
$29.95 for 32 ounces.
100 gal fill up of 91 would be $89.85 to get to 95 octane
