Video Memorial Weekend Fun
Ran 110 miles this past Sunday to Miami and back. These boats are a lot fun!
https://www.youtube.com/watch?v=kgveycgemLc |
Originally Posted by Double Rigged
(Post 4444250)
Ron looks like you had a great run. Boats runs very nice. I was out as well fun boats.
Good stuff!
Great Vid, Ron! How are you getting depths? What props are you running? The boat doesn't seem to porpoise much!
This boat has an in hull transducer feeding the Smartcraft. It is getting into the Garmin through the gateway. However if you had a smart sensor on yours it would also get to the VIRB. It is one of the items being transmitted over. I am working with them on adding more information from the engine side. Hopefully sometime down the road it will happen.
Props are my everyday 29p 5blade Dewalds. |
(Post 4444329)
Sam
Try using the VIRB Edit software and publish to YouTube. |
Ron, exactly where do you have your transducer? I thought there were issues with the airation from the hulls at speed??? What is a smart sensor? Sam, what are the "future motors"??
(Post 4444369)
Sam
Double Rigged, you mind sharing the part number on the "in hull transducer" I have been looking for one. I am running a Vessel View Race Edition.
thanks,
(Post 4444329)
Originally Posted by jpf091959
(Post 4444825)
thanks, |
Thank you sir. you always given me great advice.
Originally Posted by Taboma
(Post 4444374)
Hey David,
Sorry forgot about it. Getting old sucks. The transducer on this boat is mounted in the back low in the sponson. It goes against everything we know about proper installations in what we do and what manufactures recommend. Peter did do a core out and filled the void with solid fiberglass. You can buy an in-hull version NMEA2000 for the Garmin and put it right in the backbone. I can ship you one if you like. The housing you can epoxy in and fill it with mineral oil or antifreeze. It seems to work ok. I have not really paid attention to it but will next time out to make sure it is working. Hope this helps. |
(Post 4446683)
Hey David,
| All times are GMT -5. The time now is 06:34 PM. |
