Breaker or Fuse ?
Having some power problems. lost 12v on one motor.
Was wondering if Sonic put a main breaker in somewhere that i am missing. http://www.offshoreonly.com/forums/s...=1#post1335633 |
Re: Breaker or Fuse ?
If its like an automotive fuseable link, they're a one shot deal. Once blown its over with....need to replace it.
Boating is fun, but most of the stuff that needs to be fixed,repaired,replaced or checked is in an out of the way place & you have to either be Gumby or the incrediable shrinking man to get to it with performing major surgury in taking things off or out to try to fix it. Check the breaker on the back of the manifold, I belive its a 50 amp push to reset, then I would check all the fuses behind the dash board. Then if all that fails, surgury time to get to the starter & the fuseable link. Good luck. |
| All times are GMT -5. The time now is 12:43 AM. |
