Re: water leak
If you have the pull up cleats they DEFINITELY leak. They leak through the detent holes in the body of the cleats that are usually covered with silver stickers.
Re: water leak
I have checked all the leaks that have been suggested and all are dry and the leak is not coming from the out side. I am almost possitive that the hoses that feed the sink from the tank and the pump are leaking. I am goping to replace them but think I need to pull the floor up to get to the tank? I am going to call sonic in the am. Thanks for all your help and I will keep you up to date.
Terry P.S. Brian is your drive going to be ready for Maryland? |
Re: water leak
Re: water leak
We had a problem with water coming forward up the drain plug into the cabin from the engine compartment and just plugged it up and that solved it. :drink: Buy a box of tampons. :drink:
Re: water leak
Your water tank may be leaking. I had that problem on my 42. It is very hard to get at, and you may need to cut a hole in the side of the cockpit if the tank itself is leaking. first thing to do is remove the water drain hose, and plugthe hole. then adapt a radiator presure tester to check the tank, then start checking the hoses the same way. There is one that goes back to the pump in the engine compatment then it comes back to the galley sink. they do not route under the floor. as it turned outn on mine the tank split a weld. I cut a hole in my cockpit liner, and made a plexi panel to cover it. kind of a rough place they put the tank but it is what it is. Good luck.
| All times are GMT -5. The time now is 02:27 PM. |
