-   Sonic (https://www.offshoreonly.com/forums/sonic-46/)
-   -   Help with sonic step plate.. (https://www.offshoreonly.com/forums/sonic/177024-help-sonic-step-plate.html)
tfarmer 01-08-2008 08:55 PM
1 Attachment(s)
Ok Sonic owners I have a question. I have a 2001 260
Prowler. I think It was about a year ago I seen a thread about
alum.(candy purple) step plates. Im not sure if someone just made themself a nice set or if they were purchased? I would like to have a set of them for my boat. I think it ads a nice touch. Could any one help on this?
Here is a pic of mine they are hard plastic white.
Sydwayz 01-08-2008 09:14 PM
http://www.eddiemarine.com/store/car...l&p=12232&c=30
26Sonic and I spearheaded having these specially made by Eddie Marine several years ago. The XL size (linked above) is what you are looking for; and just pick your color choice.
Search " Sonic step pads " for several threads to pop up.
tfarmer, didn't you live in VA? If so, when did you move to KY?
tfarmer 01-08-2008 09:45 PM
Thanks for the help I will check them out now.
I have been in Paducah, Ky. All my life. Far west of the state. We have a great place to boat. Check out kentucky lake.com
Key words: poker run, lbl, Fishing.
Thanks again,Timmy F.
GO4BROKE 01-08-2008 09:55 PM
They are a huge upgrade, you'll like them.
Here's Johnny 01-09-2008 04:40 AM
What size is used on a 358..........?
Sydwayz 01-09-2008 07:02 AM
tfarmer, I must have been thinking of someone else here on the board.
Here's Johnny,
To my knowledge, they ALL use the same size pad. I measured a 26, a 28, a 31, and a 386 when I was gathering requirements. They are actually 1/16" smaller than the OE plastic pads, so as not to risk a cut into the vinyl going up the armrests. The holes are drilled in exact same locations, so you won't even have to re-drill; 5 minute install.
Some of the old posts have a bunch more info and pics.
Here's Johnny 01-09-2008 05:17 PM
THanks Brian..............
tfarmer 01-09-2008 08:56 PM
Here's Johnny,
I ordered them to day. They will be here in a few days.
One more question. I have all my service work done for spring (oil,filter,Out drive service, fuel filters,water filter, spark plugs. all that stuff) But what im not sure of is grease fittings? I think I
was reading a thread and some guys were talking about grease fittings in or around the bellhousing area? I have the engine hatch off and it is easy to get in the back but Im not sure where to look. I didnt see any right off when I got down in there. I dont want to look over anything, Much
less a few grease fittings. The only one I could find back there was on the steering unit. Its a 496 ho mag with bravo-one.
I bought the boat used and I dont have a owners manual.
(Im not even sure if boats have manuals)
Thanks again. Timmy Farmer.
Sydwayz 01-09-2008 10:14 PM
Timmy, that's better off posted in the Tech Section. Each year and model of drive and transom assembly could be different. I can only get to the grease fitting on the outside of my transom assembly.
Have you pulled your drive, and inspected (and lubed if equipped with zerks) your U-joints? While the drive is off, its an ideal time to inspect your alignment, which will require a tool from your closest Mercury Mechanic friend for about 10 minutes. You will also need a Bravo 1 Installation kit to re-install the drive. Its about $12 bucks and includes all the O/Odd-rings for the shaft and the drive to outer bellhousing fitment. Its a good idea to do this once a year.
tfarmer 01-10-2008 08:27 AM
That sounds good. I have not had it off and I Have used the boat for two seasons. I did install a new imco soprtsmaster
lower last year. But never removed the upper unit. I will do all
that next. Thanks again. Timmy.
