Shore Power Question.....
Make sure you have the "Main"breaker in the off position. This will protect your boat and the power cable. Once plugged in turn on the Main and the other breakers that you will need. Leave the battery switches and the 12 volt breakers in the on position. While you are in the slip turn on the battery charger when you have lights and other 12 volt accesories on. Hope this helps.
