-   Sonic (https://www.offshoreonly.com/forums/sonic-46/)
-   -   Trim tab Indicator cables (https://www.offshoreonly.com/forums/sonic/192567-trim-tab-indicator-cables.html)
GoFastSonic 08-04-2008 11:58 AM
Trim Indicator cables
How hard are they to change on a 2001 31?
Mine got stuck out and when I trimmed the tabs up the cables both bent.
45sonic 08-04-2008 12:08 PM
Same for your boat almost
http://www.offshoreonly.com/forums/s...trim+tab+cable
GoFastSonic 08-04-2008 10:09 PM
Thanks for the info where would the part numbers be on the cables?
45sonic 08-05-2008 07:05 AM
On either end or some have them spread along the cable itself. You can also measure the length and order them that way.
powerquest280 08-05-2008 10:52 AM
Trim Tab Cables
I hope my step by step helps. Glad to see it was referred to. Please write to me if you need more info. There should be cable numbers on the old cables. The starbaord cable is shorter than the port cable.
Mike
