-   Sonic (https://www.offshoreonly.com/forums/sonic-46/)
-   -   Please explain this...... (https://www.offshoreonly.com/forums/sonic/224323-please-explain.html)
wet_rat 02-11-2010 02:37 AM
http://www.teamshogren.com/pre-owned...-42-sonic.html
20th picture that shows the sea strainers. Does it not look as if the starboard side strainer pick up is directly behind it through the bilge floor?
45SS 02-11-2010 10:56 AM
It probably does. My generator and A/C both come through the bilge floor, never had a problem. If you are running in a river or a lake, with varying water levels where it washs sticks and debris off of the banks and shore you will be constanly bending and tearing up water pick-ups off of transom.
Plum_Crazy 02-11-2010 01:02 PM
I bet both pickups are through the bottom. You just can't see the Port side. My A/C water pickup is also like this. It has a clamshell style grate.
Thanks for bringing this up. I just realized that if I turn that grate around backwards, I'll have less drag. Since I can only run the A/C on shorepower, It doesn't matter what direction it faces.
wet_rat 02-11-2010 04:22 PM
thanks for explaining......first time I have heard of this. Any known history of issues with hull rot around the pick up?
