on/off switches on dash?
who is the manufacurer of the white on/off switches with the red window so you can see when there on or off by the lite shining thru for the various accessories on the dash panel ?
I'm assuming you're looking for rocker switches? Some rockers switches and regular toggles have the ability to light up (red - or white) when the switch is activated. You'll find manufacturers under the following names:
Carling Technologies http://switches.carlingtech.com/index.asp Cole Hersee http://www.colehersee.com/catalog_top/index.htm Sierra http://ww2.sierramarine.com/sierra/c...a/category.asp I've sourced the toggles from Newak Electronics, defender.com and most recently http://www.inetmarine.com/ where I found a really old style toggle for my Scarab. It has a clear tip, which lights up red when I flip it on. |
You can have mine.
look at kendor marine. also called great lakes skipper. look in the baja section. they have them labeled and blank.
could'nt find the section you were refering to , can you give the link for it ? thanks
| All times are GMT -5. The time now is 12:19 PM. |
