-   Sonic (https://www.offshoreonly.com/forums/sonic-46/)
-   -   31 SS Ignition Question (https://www.offshoreonly.com/forums/sonic/254613-31-ss-ignition-question.html)
MDsteve410 05-29-2011 09:11 AM
Hey Guys:
2007 31SS twin 496HO's, port engine when I turn the key will barely crank over, when I return the key to the off position and wait a few seconds then retry it fires right up strong. I have load tested the batteries and they are strong any ideas ?
Thanks,
Steve
teamsynergy 05-29-2011 10:53 AM
Originally Posted by MDsteve410 (Post 3415179)
Hey Guys:
Thanks,
Steve
Sounds like a possible starter problem... Have you tested the draw when the problem occurs vs. when it starts ok?
GO4BROKE 05-29-2011 07:29 PM
Starter is likely on the way out. Check the voltage drops on the cables, check the connections before you buy a starter.
MDsteve410 05-29-2011 08:57 PM
Thanks guys I was leaning starter too....the Chesapeake Bay was rough as hell this weekend so tomorrow is a fix it day for everything that rattled loose so I will check the connections and draw on the starter tomorrow.
