Aluminum Exhaust Manifolds ?
Anyone using aluminum manifolds on a 502?
What are the pros and cons? Looking to replace mine on my Prowler next Spring. From what I have read they seem to flow better, weigh less but corrosion from dissimilar metals seems to be an issue. Looking for experience opinions. Ed '99 Sonic Prowler '96 Scarab 22 (4 sale) |
Originally Posted by U4ICK
(Post 3550082)
Originally Posted by ridefast77
(Post 3550197)
pros...There a lot lighter and the ports are bigger so you get more air flow = more HP and they look good...cons, there are none if any thing cost i guess.
Ed |
(Post 3550268)
Thanks for the feedback. I was looking at the Moore Performance manifolds. They are advertised at $229.00 each; the same as iron manifolds.
Ed |
(Post 3550282)
thats cheap
Moore's manifold and 4" riser kit is $669. I'm not sure if that is an all aluminum kit. From what I read putting iron risers on aluminum manifolds is a no-no. But the manifolds bolt to an iron block. I understand the dissimilar metal issues but I guess I'm confused about the risers! Am going to do more research and talk with Moore before I buy. Here is the site: http://www.mooreperformance.info/Mer...ifoldkits.html Ed |
I would go with CMI E Tops.
I went with Revolution Marine for aluminum manifolds and risers on my 26 Prowler, 502-425hp. Slight increase in performance but it took almost 75 lbs off the back of the boat. Aluminum manifold and riser was an exact fit. No modification was necessary to any other components - simply bolt on.
i used stock 496 aluminum manifolds takeoffs came with stainless risers bought them for small money i have a couple risers left if you need them
Originally Posted by BlowMe
(Post 3592041)
Do you have Captain's Choice? Ed |
(Post 3595214)
That looks like a good product.
Do you have Captain's Choice? Ed Yes I do. They bolted on just like OEM manifolds. No modifications had to be made to the oil filter mount, brackets, etc. |
| All times are GMT -5. The time now is 07:04 PM. |
