1999 SONIC 358 Drive Spacer Recomendation
I am going to install drive spacers in my 1999 SONIC 358 twin 550HP/500 HP rebuilt engines with bravo 1 drives and 28 pitch 4 blade bravo props turning inward. I am experiencing prop blowout getting on plane and bow hop once its on plane.
Has anyone installed drive spacers on a 358 to eliminate a similar problem? Should I go with 1", 2" 3" spacers? Any help is appreciated. Thanks, Tom |
I don't own a Sonic, but have been researching them pretty hard. Seems most folks with the porpoising issue trade up to a 5 blade Hydromotive, same as the Nordic folks. In the Nordic world those things cure damn near every negative effect known to man. You could always try to measure your X-dimension and see if a spacer is truly needed. Not sure what the happy height for a 358 is. Maybe someone will chime in. Good luck either way!
Jay |
How does the ride change if you spin props out?
Jay
You may be on to something with the 5 blade props. Tom |
I switched the props so they were spinning out and it was still bow hopping.
Mine spin out.
I get the bow hop but it is super easy to tab into control.
Originally Posted by tomswift
(Post 4354693)
Has anyone installed drive spacers on a 358 to eliminate a similar problem? Should I go with 1", 2" 3" spacers? Any help is appreciated. Thanks, Tom The notched transom puts the props in "cleaner" water when running in the rough stuff; which is what allows these heavy boats to carry the nose when needed. Some folks have gone so far as to fill in the notched transom to run a true squared transom; when they run primarily flat water and have not been able to get the porpoise dialed out. |
| All times are GMT -5. The time now is 01:29 PM. |
