1996 sonic 35ss cable # or ft size 33c
The length will be in the part number on the end of the cable. This one will be a hassle to get to. I would remove the end at the indicator first as that one will probably be the easiest to get to. Pull it out into the dash area or head and rotate it around to find the number. Otherwise you will have to take the assembly off of the drive to look at the other end. Not a terrible job on a Sonic as everything is fairly easy to get to .
