-   Sonic (https://www.offshoreonly.com/forums/sonic-46/)
-   -   Nova Kool refridge help (https://www.offshoreonly.com/forums/sonic/82111-nova-kool-refridge-help.html)
roadrunner 06-26-2004 06:40 AM
I can't seem to get the fridge to work.
does enyone know where the fuse is to this unit?
I can feel the nuts on some of the bolts that hold the fridge in place
It is the only manual that I didn't get with the boat.
I will have to break the sealer to remove the fridge so I want to make sure that
the fuse is back there. eny ideas would be a great help!!!(My Beer Won't Stay Cold)
RR
The boat is a 2003 358
HiPerf2000 06-26-2004 10:23 AM
Re: Nova Kool refridge help
Check the fuse panel behind the dash (in the head). there are labeled fuses back there.
roadrunner 06-26-2004 02:55 PM
I have looked there behind door in head and have not found a refridge fuse.
NJSONIC 06-27-2004 09:33 AM
Roadrunner,
Do you have all the correct switches turned on? The one one the dash by your gauges,and the one on the panel in the cabin?
Hope this helps.
splashandburn 06-27-2004 09:01 PM
RR
Roadrunner,
I had the same problem with my fridge. There is a breaker panel of sorts on the port side in the engine compartment. It is tucked up near the water pump - in that general area. Once you reset that switch yo should have cold beer again. let me know if you can't find the breaker.
roadrunner 06-28-2004 10:15 PM
Ok. Both switches are on ,the one on dash and the one in cabin.
the breaker by the water pump has been reset. the terminals on the battery
have been cleaned . I pulled the fridge ,there is a fuse on the
left side of the fridge . that fuse is ok. there is juice going fridge through
12 volt line coming from battery. Shore power is plugged in.any more ideas?
thanks
splashandburn 06-29-2004 06:35 AM
Sounds like something went on the fridge - if yo have power going to it it should turn on. It could also be the thermostat itself. I'm not sure how to test that switch but there must be a way to do it. Sorry I can't be more help.
roadrunner 06-30-2004 09:28 PM
Found it! Used a jumper wire on the back panel I used a trouble shooting guide
that I found from Nova Kool When I used the jumper wire the compresser
came on . using the trouble shooting guide it lead me to the fact that the thermostate is bad. now I need to order .Thank you all for your suggestions
hope this help someone else in the future if they have the same problem.
RR
