-   Spectre (https://www.offshoreonly.com/forums/spectre-48/)
-   -   30' with 300's water pressure question...... (https://www.offshoreonly.com/forums/spectre/102231-30-300s-water-pressure-question.html)
Andy01 05-02-2005 03:56 PM
How much water pressure are you some of you seeing? I don't have low water pick ups just the stock deal in the lower. I am wondering what some of you are running your boats at?
What kind of speeds are you guys getting out your boat at what rpm?
I ran 100mph, 20psi water, 6200rpm with four people, 3/4 tanks, 90 degree air temp. at about 500 feet elevation.
Andy
berns29scarab 05-02-2005 07:25 PM
Re: 30' with 300's water pressure question......
i'm at 100 at 6000rpms 15-18 psi, 4 guys 2-225 pounds, and both tanks at 3/4's turning 15x32 3 blade labbed props no tab in a 1 ft chop..that mile per hour is from a garmin 182c as well as a gaffrig gps with tattletale
Pmpaint1 05-02-2005 08:09 PM
Both you guys are pretty much right there I ran 101 with 3 people half tank at 6000 with my 300xs
Sean H 05-02-2005 08:18 PM
i run 25-30 psi (need to get a relief valve) at 105 or so with 2 people and half tanks...... oh wait, i don't have 300's :D :D
Donzi Corleone 05-02-2005 09:16 PM
105 6300rpm with 3/4 tank and 2 guys me at 230lbs Water pressure 15-18 3 blade 15x32 labbed cleavers 1 ft chop saltwater....Like sitting on a aircraft wing just floating. No other feeling like it!!
Andy01 05-05-2005 10:39 AM
Thanks for the replies, I might try and run the ocean this Saturday if the weather is decent. It is raining here in So.Cal right now. Hoping for 105 in the salt, then raise the motors a 1/16 or so more and pull 108. If not I will start throwing seats and people out of the boat until I get there. :D
dreamboater 05-05-2005 11:59 AM
I run 300's with a 28 Skater, my gauges are only registering 10-12 psi. I did move the motors back and up this year, still experiencing with the height. My water temps stay normal, however the water is still quite cold.
Not to bust in on every spectre thread, just not many skaters on this board, atleast with O/B's.
Andy01 05-05-2005 03:18 PM
Thanks for the info. I want to run mine with less then 15 to see how much if any faster it will be. I was told if you drop below the 15 mark the motors will go into thier safe mode and drop to 3000rpm. What type of speeds are you seeing out of your Skater?
Andy
dreamboater 05-05-2005 04:40 PM
Andy
Unless going my gauges are off, I am not going into safe mode. I am running 300 Promax's, Not X motors. Dont have any real high speeds to show yet. I have run 104.5 with full fuel and 3 people and gear in the boat only turning 5900 so far. Realisticly, the boat should run 110 maybe 112 on its best day, which is about what most full interior pleasure versions run with these motors. I am still playing with my motor height and props to see what combo gives me my best speeds. I am running a new set of 3 blade 15x34 lab Merc cleavers, I will probably end up cutting them down to 14 3/4 or even 14 1/2 to get some extra rpm.
