-   Spectre (https://www.offshoreonly.com/forums/spectre-48/)
-   -   30' spectre - Front seats too low? (https://www.offshoreonly.com/forums/spectre/348382-30-spectre-front-seats-too-low.html)
life is good 07-13-2017 11:55 AM
I have a 2006 30' spectre with the small windscreen. I find the front seats to be too low to see out the boat. I am 5'10" so I would say I'm average height, but I have to sit on two throwable cushions while driving. Has anyone else had this same problem? If so I wondering if anyone knows a good type of bracket to mount under the seats to raise them up.
Big Block 07-17-2017 12:03 PM
I ended up raising my seat 3" so I could see over the windscreen. I kept the passenger seat the same height so my wife could not see over the dash and tell me to slow down, lol
Big Block 07-17-2017 12:04 PM
life is good 07-17-2017 09:41 PM
Did you have to make brackets to raise your seat or were you able to buy something that worked well?
I was thinking more along the lines of an ejection seat for my wife.
Big Block 07-18-2017 09:07 AM
I bought rubber tile(24"X24" I think) and cut it to match the bottom of the seat and then covered it with the same carpet I have on the floor. Stacked it between the floor and the seat to raise it up to the height I needed. Wanted something that would not rot and I don't have fiberglass experience to build a taller base. It actually looks OK for cheap easy way to do this.
Andy01 07-19-2017 09:49 PM
I believe Jay use to use some shims. I owned a 2005 30 with the windshield and I think I adjusted my seat as well.
drksuroo 07-23-2017 09:41 PM
I have booster cushions that go in the seats. I'm a little taller but it definitely helps me.
Rockyone 07-25-2017 10:04 AM
Why not just have the seat bottoms redone with thicker foam?
life is good 07-25-2017 10:33 AM
I found some garlick mounts that will add 2" in height and also allow the seat to slide fore and aft. I haven't installed them yet.
